跳转到主内容
Matsunichi MarquisPad MP977 Front Facing Camera Replacement
你所需要的
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,1
    • Using the PH #00 Phillips head screwdriver, unscrew the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 2 中的图像 1,3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 2 中的图像 2,3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 3 中的图像 1,2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
    • Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the back plate and place it to the side of the device.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    • With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they wont fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 6 中的图像 1,2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 7 中的图像 1,2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Last, Insert the new camera into the pinhole camera slot.
结论
团队
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 221
