跳转到主内容
Matsunichi MarquisPad MP977 Battery Replacement
你所需要的
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: 步骤 2 中的图像 1,3 Matsunichi MarquisPad MP977 Battery Replacement: 步骤 2 中的图像 2,3 Matsunichi MarquisPad MP977 Battery Replacement: 步骤 2 中的图像 3,3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: 步骤 3 中的图像 1,2 Matsunichi MarquisPad MP977 Battery Replacement: 步骤 3 中的图像 2,2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: 步骤 5 中的图像 1,2 Matsunichi MarquisPad MP977 Battery Replacement: 步骤 5 中的图像 2,2
    • Detach the battery from the motherboard.
结论
3等其他人完成本指南。
Evan Campbell
于03/24/15注册
88 声望
撰写一个指南
团队
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,554
