跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Matrox TripleHead2Go Display Adapter,应参考我们的维修指南
  1. Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: 步骤 1 中的图像 1,3 Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: 步骤 1 中的图像 2,3 Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: 步骤 1 中的图像 3,3
    • The first step is to unscrew all screws.
    • Second one is to insert something at the shown edge pull gently but firmly apart, alternating sides.
    • At the end, it will come off sideways.
    • It will be full of tiny copper pieces. Actually they won't be where you see them in the picture, but pulled off and laying around. You will need them to reassembly.
  2. Matrox TripleHead2Go Display Adapter Teardown, The card at daylight: 步骤 2 中的图像 1,2 Matrox TripleHead2Go Display Adapter Teardown, The card at daylight: 步骤 2 中的图像 2,2
    • This is how the card looks. Well made, isn't it?
    • If you turn it around, you will see on two chips the heat dissipating creme. Maybe you want to change it.
  3. Matrox TripleHead2Go Display Adapter Teardown, The other way round: 步骤 3 中的图像 1,1
    • To reassemble the card, just go the same way back. You can see the positions of the copper pieces in the previous step (I guessed them by the marks in the metal), and the one of the screws in the first step. Easy, isn't it?
leon
于09/28/11注册
133 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 411
