跳转到主内容
Masterbox Lite 5 Mid Tower Case RAM Replacement
你所需要的
  1. Masterbox Lite 5 Mid Tower Case RAM Replacement, RAM: 步骤 1 中的图像 1,2 Masterbox Lite 5 Mid Tower Case RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Power down the PC.
    • Disconnect all cables from the PC, including the power cable.
    • Other cables may include: mouse, keyboard, monitor’s HDMI cable, Ethernet, and USB cables.
  2. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 2 中的图像 1,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 2 中的图像 2,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Attach the anti-static wrist strap to your wrist.
    • Connect the cable to the wrist strap.
    • Attach the metal prong on the cable to a grounded metal surface.
  3. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 3 中的图像 1,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 3 中的图像 2,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 3 中的图像 3,3
    • Unscrew the four 7 mm screws from the corners of the panel using a Phillips #00 screwdriver.
    • Lift the plastic side panel carefully and put it to the side.
    • This will expose the main motherboard with all of its components such as the CPU, RAM, graphics card, storage drive, power supply, and cooling fans.
  4. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 4 中的图像 1,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 4 中的图像 2,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 4 中的图像 3,3
    • Press on the tabs on each side of the RAM stick.
    • Do not simply grab and pull, as this will cause damage to the motherboard.
    • Pull out the RAM once it pops up.
  5. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 5 中的图像 1,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 5 中的图像 2,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 5 中的图像 3,3
    • Align the notch on the bottom of the RAM with the notch on the motherboard port to avoid damage to the board or the RAM.
    • Apply some pressure for the prongs on the side to clip in the RAM stick.
  6. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 6 中的图像 1,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 6 中的图像 2,3 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 6 中的图像 3,3
    • Put the plastic side panel back on.
    • Align the screw holes to the ones on the PC case.
    • Screw in the screws in all four corners to hold the side panel in place using a Phillips #00 screwdriver.
  7. Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 7 中的图像 1,2 Masterbox Lite 5 Mid Tower Case RAM Replacement: 步骤 7 中的图像 2,2
    • Connect all of the previously connected cables from the back.
    • Cable may include the mouse, keyboard, monitor’s HDMI cable, Ethernet, and USB cables.
    • Connect the power supply cable back to the power and the PC.
    • If the switch of the power supply is off, please turn it on.
    • Test to see if the PC starts up without any errors.
    • If the computer does not start or gives you an error. Please restart this process from Step 1.
结论
After purchasing the correct RAM module for the correct motherboard, this guide will take about 15 minutes to accomplish successfully.
If you run into any booting issues and cannot fix it, please install the previously used RAM module.
If it boots up using the previously installed RAM stick, please review to see if the correct RAM was purchased for your specific motherboard.
3等其他人完成本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 32
总计 2,985
