跳转到主内容
MasterCraft Eliminator Waterproof Spotlight Battery Replacement
你所需要的
  1. MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: 步骤 1 中的图像 1,2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Twist the front cover of the spotlight in a counter-clockwise rotation and remove it from the device.
  2. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 2 中的图像 1,2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the rear piece which is the protection cover for the charging port.
  3. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 3 中的图像 1,2 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 3 中的图像 2,2
    • Using the JIS #00 screwdriver, remove the two screws securing the motherboard to the device.
  4. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 4 中的图像 1,3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 4 中的图像 2,3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 4 中的图像 3,3
    • Using the JIS #00 screwdriver, remove the single screw securing the charging port and remove the charging port from the device.
  5. MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 5 中的图像 1,3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 5 中的图像 2,3 MasterCraft Eliminator Waterproof Spotlight Battery Replacement: 步骤 5 中的图像 3,3
    • Carefully disconnect the battery and remove it from the device.
结论
另外一个人完成了本指南。
一条评论
Can you get the 3wledbulb
olddoc55 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 46
总计 1,490
