跳转到主内容
加入维修社区 - 创建账户
Master and Dynamic MW50 Disassembly
你所需要的
  1. Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 1,3 Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 2,3 Master and Dynamic MW50 Disassembly, Master and Dynamic MW50 Disassembly: 步骤 1 中的图像 3,3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Disassembly: 步骤 2 中的图像 1,1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Disassembly: 步骤 3 中的图像 1,1
    • Use the Jimmy to lift up the black cover to get inside the device.
结论
另外一个人完成了本指南。
Ryan Chan
于01/24/19注册
297 声望
创作了2篇指南
团队
Cal Poly, Team S1-G4, White Winter 2019 Cal Poly, Team S1-G4, White Winter 2019 的会员
CPSU-WHITE-W19S1G4
4 名成员
创作了12篇指南
1指南评论
My right side doesn’t work on Bluetooth mode but works fine with ord any help would be greatly appreciated
James Dunleavy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 745
