跳转到主内容
MartinLogan Motion 4i Woofer Replacement
你所需要的
  1. MartinLogan Motion 4i Woofer Replacement, Back Cover: 步骤 1 中的图像 1,2 MartinLogan Motion 4i Woofer Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the speaker grill from the face of the speaker by using both hands to grip both ends of the speaker grill and pulling up to release the magnetic ends.
  2. MartinLogan Motion 4i Woofer Replacement: 步骤 2 中的图像 1,3 MartinLogan Motion 4i Woofer Replacement: 步骤 2 中的图像 2,3 MartinLogan Motion 4i Woofer Replacement: 步骤 2 中的图像 3,3
    • Remove the six caps from the outer edge of the face of the speaker with an iFixit opening tool.
    • Make sure to remove the rubber caps slowly and carefully so that the ends won't break off and create a blockage above the screws.
  3. MartinLogan Motion 4i Woofer Replacement: 步骤 3 中的图像 1,1
    • Remove the six 4 mm Phillips #2 screws that are located inside each of the holes where the rubber caps used to be.
    • The screws vary in depth, therefore you will need a Phillips #2 screwdriver that is around 6 inches in length from the tip to the start of the handle.
  4. MartinLogan Motion 4i Woofer Replacement: 步骤 4 中的图像 1,1
    • Place the device face-down, then lift off the back case with both hands.
    • The speaker sometimes takes a little effort to remove the speaker back, so we recommend that you give it a couple shakes by placing each hand on the speaker face and the back when shaking.
    • If you decide to use the shaking method, make sure you're near an immediate surface near you just in case it drops.
  5. MartinLogan Motion 4i Woofer Replacement: 步骤 5 中的图像 1,1
    • Lightly grip the material that insulates and covers the speaker components and remove it by pulling up.
  6. MartinLogan Motion 4i Woofer Replacement: 步骤 6 中的图像 1,2 MartinLogan Motion 4i Woofer Replacement: 步骤 6 中的图像 2,2
    • Remove both wires that are connecting the back of the speaker to the components of the speaker to fully access the speaker components.
  7. MartinLogan Motion 4i Woofer Replacement, Woofer: 步骤 7 中的图像 1,1
    • Remove the 3 mm Phillips #2 screws around the woofer.
  8. MartinLogan Motion 4i Woofer Replacement: 步骤 8 中的图像 1,1
    • Lift the woofer out of the speaker base.
  9. MartinLogan Motion 4i Woofer Replacement: 步骤 9 中的图像 1,3 MartinLogan Motion 4i Woofer Replacement: 步骤 9 中的图像 2,3 MartinLogan Motion 4i Woofer Replacement: 步骤 9 中的图像 3,3
    • Desolder the wires off the woofer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 53
