跳转到主内容
Martian Victory Watch band Replacement
你所需要的
  1. Martian Victory Watch band Replacement, Watch band: 步骤 1 中的图像 1,1
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: 步骤 2 中的图像 1,1
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: 步骤 3 中的图像 1,1
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
结论
Dominic Coffey
于10/24/16注册
243 声望
创作了2篇指南
团队
IUPUI, Team 3-3, Baechle Fall 2016 IUPUI, Team 3-3, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S3G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 9
总计 278
