跳转到主内容
Marshall Woburn Subwoofer Replacement
你所需要的
  1. Marshall Woburn Subwoofer Replacement, Back Panel: 步骤 1 中的图像 1,2 Marshall Woburn Subwoofer Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Subwoofer Replacement: 步骤 2 中的图像 1,2 Marshall Woburn Subwoofer Replacement: 步骤 2 中的图像 2,2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Subwoofer Replacement: 步骤 3 中的图像 1,1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn Subwoofer Replacement, I/O Board: 步骤 4 中的图像 1,1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn Subwoofer Replacement: 步骤 5 中的图像 1,2 Marshall Woburn Subwoofer Replacement: 步骤 5 中的图像 2,2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn Subwoofer Replacement: 步骤 6 中的图像 1,1
    • Completely remove the I/O board and the attached plate.
  7. Marshall Woburn Subwoofer Replacement, Subwoofer: 步骤 7 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
  8. Marshall Woburn Subwoofer Replacement: 步骤 8 中的图像 1,1
    • Lift each subwoofer up and out of the case and remove them together. This may require some foce.
结论
Kenneth
于10/29/23注册
169 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 38
总计 211
