简介
Was the back of your Marshall Woburn damaged or do you need to access any components inside of it? If so, here is the guide on how to open up the back panel. All you need is the standard #1 Phillips Screwdriver head to remove the screws involved with this replacement.
你所需要的
On a flat surface, orient the device so that the front grille is facing downward.
Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
即将完成!
结论
