简介
This guide is intended to replace the internal power jack in the Marshall Stanmore II Bluetooth Speaker.
The power jack provides power from the external cable that is plugged into the outlet to the speaker's internal components. This allows the speaker to turn on and play audio from any Bluetooth-capable device. Since the speaker doesn't contain a battery, the power jack must function as intended for the speaker to power on.
Before using this guide, verify that you are not using a faulty power outlet. This can be checked by plugging in another device and making sure that it works as intended. Now, follow the Marshall Stanmore II Troubleshooting guide in case there is a simpler solution before disassembly.
你所需要的
Set the panel back in place.
Use a #1 Phillips screwdriver to remove the two 11.7 mm screws that secure the power jack.
