跳转到主内容
Marshall Monitor Headset Audio Cable Repair
你所需要的
  1. Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: 步骤 1 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: 步骤 1 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: 步骤 1 中的图像 3,3
    • Examine the point at which the cable enters the housing to identify the location of the damaged part of the cable.
  2. Marshall Monitor Headset Audio Cable Repair: 步骤 2 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 2 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 2 中的图像 3,3
    • Remove the foam cushion and remove the 4 screws with a Torx screwdriver.
    • Be careful to carefully remove the upper part of the headset.
  3. Marshall Monitor Headset Audio Cable Repair: 步骤 3 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 3 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 3 中的图像 3,3
    • Unsolder the faulty cable connections.
    • Two of the wires are soldered to the transducer (one for ground and one for signal). The third is connected to the input of the 3.5 mm audio jack.
    • Remove the inner foam and undo the cable knot to take it out of the headset.
  4. Marshall Monitor Headset Audio Cable Repair: 步骤 4 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 4 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 4 中的图像 3,3
    • Cut the cable upstream of the damaged area and remove 10mm of insulation.
    • Prepare the wires for soldering. For this, the enamel that isolates the wires from each other must be removed using medium to fine grain sandpaper (120 - 180gr).
    • Next, tin the 3 wires.
  5. Marshall Monitor Headset Audio Cable Repair: 步骤 5 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 5 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 5 中的图像 3,3
    • Solder the 3 replacement wires and mark the corresponding color.
    • Isolate the 3 solder points by placing the heat shrink tubing on each solder joint.
    • Cover the three wires with another piece of heat shrink tubing.
  6. Marshall Monitor Headset Audio Cable Repair: 步骤 6 中的图像 1,1
    • There is a good chance that the diameter of the replacement cable will be greater than the original. In that case it will be necessary to remove the original gold cable grommet (it is decorative anyway).
  7. Marshall Monitor Headset Audio Cable Repair: 步骤 7 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 7 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 7 中的图像 3,3
    • Reinsert the cable into the headset
    • Solder the wires to their original locations
    • Place a dot of hot glue where the new cable passes through to hold it in place and avoid strain on the connections.
  8. Marshall Monitor Headset Audio Cable Repair: 步骤 8 中的图像 1,3 Marshall Monitor Headset Audio Cable Repair: 步骤 8 中的图像 2,3 Marshall Monitor Headset Audio Cable Repair: 步骤 8 中的图像 3,3
    • Replace the foam inside the headset then gently reposition the upper part.
    • Tighten the 4 Torx screws and replace the foam of the outer pads.
结论
Crank up the volume!
4等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
一条评论
protip, you should not fold the headphones like the first picture. its was causes the damage to begin with.
Thomas DH - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 58
过去 30 天: 315
总计 9,724
