跳转到主内容
Marshall MS-2 Speaker Replacement
你所需要的
  1. Marshall MS-2 Speaker Replacement, Disassembling Marshall MS-2 Micro Amp Case Disassembly: 步骤 1 中的图像 1,1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Marshall MS-2 Speaker Replacement: 步骤 2 中的图像 1,3 Marshall MS-2 Speaker Replacement: 步骤 2 中的图像 2,3 Marshall MS-2 Speaker Replacement: 步骤 2 中的图像 3,3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Marshall MS-2 Speaker Replacement: 步骤 3 中的图像 1,2 Marshall MS-2 Speaker Replacement: 步骤 3 中的图像 2,2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Marshall MS-2 Speaker Replacement: 步骤 4 中的图像 1,1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Marshall MS-2 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
  6. Marshall MS-2 Speaker Replacement: 步骤 6 中的图像 1,2 Marshall MS-2 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the two 7/16" screws located in the bottom left and top right corners with a phillips head screw driver. After removing the screws, the metal clips will need to be removed as well.
  7. Marshall MS-2 Speaker Replacement: 步骤 7 中的图像 1,1
    • You may now remove the speaker by pulling it straight out.
结论
2等其他人完成本指南。
MacKinley
于10/22/13注册
796 声望
创作了5篇指南
4条评论
So where do we find a replacement speaker? If no parts are required what is the point in taking the speaker out?
Patrick Gillett - 回复
This speaker unavailable in Marlins. Any online sources. How should an untutored amateur repairer describe the replacement in order to get the right thing
Any speaker that will fit should work. Might want to check to make sure the Watts they consume are the same. I imagine that if you put a speaker in that consumes more Watts you could potentially over heat the power supply or other components.
MacKinley - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 4,198
