跳转到主内容
Marshall Kilburn Tweeters Replacement
你所需要的
  1. Marshall Kilburn Tweeters Replacement, Battery: 步骤 1 中的图像 1,2 Marshall Kilburn Tweeters Replacement, Battery: 步骤 1 中的图像 2,2
    • Place the unit face down as shown in the picture, exposing the battery cover.
    • Remove the two 4.0mm long screws holding the cover on using a T10 driver.
  2. Marshall Kilburn Tweeters Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover using a fingernail or nylon spudger.
  3. Marshall Kilburn Tweeters Replacement: 步骤 3 中的图像 1,1
    • Remove the battery and unplug the power lead.
  4. Marshall Kilburn Tweeters Replacement, Power Switch: 步骤 4 中的图像 1,3 Marshall Kilburn Tweeters Replacement, Power Switch: 步骤 4 中的图像 2,3 Marshall Kilburn Tweeters Replacement, Power Switch: 步骤 4 中的图像 3,3
    • Place speaker as shown in image and remove the four corner 45.5mm back cover screws with a Phillips #2 driver.
    • Using a Phillips #2 driver, remove the six remaining 21.5mm outer back cover screws.
  5. Marshall Kilburn Tweeters Replacement: 步骤 5 中的图像 1,2 Marshall Kilburn Tweeters Replacement: 步骤 5 中的图像 2,2
    • Remove the back cover by using the vent hole as a grip.
    • Gently pull out the back cover and let it hang on the side of the speaker that has the knobs and power switch.
    • Unplug the main power lead from the control board; this allows the back to be opened more, allowing easy access to the power switch.
  6. Marshall Kilburn Tweeters Replacement: 步骤 6 中的图像 1,3 Marshall Kilburn Tweeters Replacement: 步骤 6 中的图像 2,3 Marshall Kilburn Tweeters Replacement: 步骤 6 中的图像 3,3
    • Pull the back cover attached to the motherboard to the side as shown in first image.
    • Remove the white insulator from the stereo speaker and place it to the side.
  7. Marshall Kilburn Tweeters Replacement: 步骤 7 中的图像 1,2 Marshall Kilburn Tweeters Replacement: 步骤 7 中的图像 2,2
    • Place the speaker up right, and unscrew the golden bolt around the power switch with your hands, or a wrench.
    • Gently pull out the power switch as shown in the image.
  8. Marshall Kilburn Tweeters Replacement: 步骤 8 中的图像 1,3 Marshall Kilburn Tweeters Replacement: 步骤 8 中的图像 2,3 Marshall Kilburn Tweeters Replacement: 步骤 8 中的图像 3,3
    • Use a slim spudger to wedge out the four red wires attached to the power switch.
  9. Marshall Kilburn Tweeters Replacement, Main Speaker: 步骤 9 中的图像 1,3 Marshall Kilburn Tweeters Replacement, Main Speaker: 步骤 9 中的图像 2,3 Marshall Kilburn Tweeters Replacement, Main Speaker: 步骤 9 中的图像 3,3
    • Unscrew the eight 22.5mm screws of the speaker cover and the device using a Phillips #2 screwdriver.
    • Gently push the speaker cover out of the stereo speaker.
    • Make sure to slowly push out the speaker cover, and not too far because it is still connected to the stereo speaker.
  10. Marshall Kilburn Tweeters Replacement: 步骤 10 中的图像 1,3 Marshall Kilburn Tweeters Replacement: 步骤 10 中的图像 2,3 Marshall Kilburn Tweeters Replacement: 步骤 10 中的图像 3,3
    • Disconnect the blue wires connected to the tweeter.
    • Disconnect the yellow wires connected to the main speaker.
    • Disconnect the red wires connected to the second tweeter.
  11. Marshall Kilburn Tweeters Replacement: 步骤 11 中的图像 1,2 Marshall Kilburn Tweeters Replacement: 步骤 11 中的图像 2,2
    • Unscrew the four 13.5mm screws connecting the main speaker to the speaker cover, with a Phillips #2 screwdriver.
  12. Marshall Kilburn Tweeters Replacement, Tweeters: 步骤 12 中的图像 1,1
    • Remove the four 13.5mm screws that are placed on the tweeters with a Phillips #2 screwdriver.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 35
总计 2,816
