跳转到主内容
Marshall Emberton Main Speaker Replacement
你所需要的
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: 步骤 1 中的图像 1,1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: 步骤 2 中的图像 1,1
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: 步骤 4 中的图像 1,1
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: 步骤 5 中的图像 1,1
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
结论
Asia Baldwin
于09/26/22注册
697 声望
创作了5篇指南
团队
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G1
5 名成员
创作了5篇指南
一条评论
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 24
过去 30 天: 137
总计 2,606
