跳转到主内容
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: 步骤 1 中的图像 1,1
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
  2. Maquet Servo-U O2 Supply Replacement: 步骤 2 中的图像 1,1
    • Lower the locking catch.
  3. Maquet Servo-U O2 Supply Replacement: 步骤 3 中的图像 1,2 Maquet Servo-U O2 Supply Replacement: 步骤 3 中的图像 2,2
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
  4. Maquet Servo-U O2 Supply Replacement: 步骤 4 中的图像 1,1
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
  5. Maquet Servo-U O2 Supply Replacement: 步骤 5 中的图像 1,1
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
  6. Maquet Servo-U O2 Supply Replacement: 步骤 6 中的图像 1,1
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
终点
团队
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 的会员
CPSU-PATON-S20S7G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 42
总计 2,010
