跳转到主内容
MapKeyboard Tutorial
    • 1. When one of your keyboard's keys is broken, you don't want to spend a lot of money to replace the entire keyboard because of one key
    • 2. You can use a software called "MapKeyboard"
    • 3. Start the software and select the key you will use to replace the broken key
    • 4. Select "ReMap selected key to" and select the broken key "G"
    • 5. Click on "Save layout" and the laptop will restart
    • 6. After restarting, you will find that the key you set can be typed with “G” so that you can continue to use your keyboard without changing it
    • 7. If you want to restore the layout of the keyboard, you can start the software again, click on "Reset keyboard layout"
    • 8.After the restart, it will be restored
结论
Laptop
于05/29/18注册
1,021 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,226
