跳转到主内容
Manual recalibration
  1. Manual recalibration, Manual recalibration: 步骤 1 中的图像 1,1
    • Open the Thrustmaster Control panel application and set the angle to 1080°
    • If you are using PlayStation, manually set rotation angle to 1080°
    • Unplug and re-plug T-GT II to USB port.
    • Wait for auto-calibration to finish
  2. Manual recalibration, Steer the wheel all the way to the left: 步骤 3 中的图像 1,1
    • Keep turning the wheel until you reach a physical stop
  3. Manual recalibration, Steer the wheel all the way to the right: 步骤 4 中的图像 1,1
  4. Manual recalibration, Center your wheel: 步骤 5 中的图像 1,1
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 1080°.
  5. Manual recalibration, Press the indicated buttons: 步骤 6 中的图像 1,1
    • Press SHARE + OPTIONS + MODE buttons at the same time.
    • LED will flash if successful.
    • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
终点
Formica Fusca
于08/01/24注册
2,595 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 24
总计 320
