简介
Follow this guide to replace the worm shaft on the Mantis 7940 Tiller (2017).
For this guide, you will need to use a hammer to tap out certain components that are friction fit into place. In order to do this, you will need to find a way to brace the tiller in place so it doesn’t move around during the process. You can use a vice, or have someone else brace the part while you use the hammer.
You will need replacement lithium grease for this repair.
你所需要的
Use a 4 mm hex wrench to remove the bolt securing the spark plug housing.
Grab the rubber housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Twist and remove the knobs and acorn nuts from either side of the handle assembly.
Remove the upper handle assembly from the lower handle assembly.
Un-clip the throttle cable from the cable clips on either side of the handle assembly and set the upper handle assembly aside.
Slide off and remove the tine retaining pin from the outer face of each tine assembly.
Use a Phillips #2 screwdriver to remove the four screws securing the gear housing cover.
Use an adjustable wrench to turn the right half (in the orientation pictured) of the tine shaft clockwise, as shown.
Continue to turn the shaft clockwise until it is unthreaded from the worm gear inside the housing.
Slide the worm gear up out of the worm gear housing about 1 cm.
Use a flat head screwdriver to separate the right worm gear thrust washer from the worm gear.
Use a pair of snap ring pliers to remove the retaining ring from the bottom of the worm housing.
Use a socket wrench with an 8 mm socket to loosen the 3/4 inch-long flange bolt from the engine flange. It is not necessary to completely remove the flange bolt.
Use a dead blow hammer to gradually tap the worm shaft assembly out the bottom of the worm gear housing.
Remove the lower worm shaft roller bearing from the worm shaft.
另外一个人完成了本指南。
