简介
Remove the legs and struts, shorten them, replace them
你所需要的
Using a drill, drill out enough of the rivet head so that the rivet may be removed.
If the rivet spins, use pliers or a flat head screw driver to hold the rivet in place
Cut spreader strut to 200mm
use a punch to mark the centre of the spreader strut
drill 6mm hole through spreader strut
round end off to replicate the original end, with a file
