跳转到主内容
Makita XPH01 LED Light Replacement
你所需要的
  1. Makita XPH01 LED Light Replacement, Battery: 步骤 1 中的图像 1,1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: 步骤 2 中的图像 1,1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: 步骤 3 中的图像 1,1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: 步骤 4 中的图像 1,2 Makita XPH01 LED Light Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: 步骤 5 中的图像 1,1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: 步骤 6 中的图像 1,2 Makita XPH01 LED Light Replacement: 步骤 6 中的图像 2,2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: 步骤 7 中的图像 1,2 Makita XPH01 LED Light Replacement: 步骤 7 中的图像 2,2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: 步骤 8 中的图像 1,2 Makita XPH01 LED Light Replacement, LED Light: 步骤 8 中的图像 2,2
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: 步骤 9 中的图像 1,2 Makita XPH01 LED Light Replacement: 步骤 9 中的图像 2,2
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: 步骤 10 中的图像 1,3 Makita XPH01 LED Light Replacement: 步骤 10 中的图像 2,3 Makita XPH01 LED Light Replacement: 步骤 10 中的图像 3,3
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: 步骤 11 中的图像 1,3 Makita XPH01 LED Light Replacement: 步骤 11 中的图像 2,3 Makita XPH01 LED Light Replacement: 步骤 11 中的图像 3,3
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: 步骤 12 中的图像 1,1
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: 步骤 13 中的图像 1,2 Makita XPH01 LED Light Replacement: 步骤 13 中的图像 2,2
    • Use tweezers to pull out the LED light assembly.
结论
2等其他人完成本指南。
Eric Herwatt
于10/05/16注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G4
4 名成员
创作了7篇指南
一条评论
Should I do these steps if my drill is under a warranty?
Richard Williams - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 43
总计 2,470
