跳转到主内容
Makita XPH01 Gear Select Switch Replacement
你所需要的
  1. Makita XPH01 Gear Select Switch Replacement, Outer Casing: 步骤 1 中的图像 1,2 Makita XPH01 Gear Select Switch Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  2. Makita XPH01 Gear Select Switch Replacement: 步骤 2 中的图像 1,1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  3. Makita XPH01 Gear Select Switch Replacement: 步骤 3 中的图像 1,2 Makita XPH01 Gear Select Switch Replacement: 步骤 3 中的图像 2,2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  4. Makita XPH01 Gear Select Switch Replacement: 步骤 4 中的图像 1,2 Makita XPH01 Gear Select Switch Replacement: 步骤 4 中的图像 2,2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  5. Makita XPH01 Gear Select Switch Replacement, Gear Select Switch: 步骤 5 中的图像 1,1
    • Pull the silver metal clip located towards the back of drill away from the motor assembly.
  6. Makita XPH01 Gear Select Switch Replacement: 步骤 6 中的图像 1,2 Makita XPH01 Gear Select Switch Replacement: 步骤 6 中的图像 2,2
    • Gently grip the front of the motor assembly and pull it out of the plastic casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor
  7. Makita XPH01 Gear Select Switch Replacement: 步骤 7 中的图像 1,2 Makita XPH01 Gear Select Switch Replacement: 步骤 7 中的图像 2,2
    • Push gear select switch forward.
    • Lift the gear select switch to separate it from the motor assembly.
结论
3等其他人完成本指南。
Eric Herwatt
于10/05/16注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 1,219
