跳转到主内容
Makita XPH01 Forward/Reverse Switch Replacement
你所需要的
  1. Makita XPH01 Forward/Reverse Switch Replacement, Battery: 步骤 1 中的图像 1,1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 2 中的图像 1,1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 3 中的图像 1,1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: 步骤 4 中的图像 1,2 Makita XPH01 Forward/Reverse Switch Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 5 中的图像 1,1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 6 中的图像 1,2 Makita XPH01 Forward/Reverse Switch Replacement: 步骤 6 中的图像 2,2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 7 中的图像 1,2 Makita XPH01 Forward/Reverse Switch Replacement: 步骤 7 中的图像 2,2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Forward/Reverse Switch Replacement, Forward/Reverse Switch: 步骤 8 中的图像 1,1
    • Pull the black trigger assembly away from the drill.
  9. Makita XPH01 Forward/Reverse Switch Replacement: 步骤 9 中的图像 1,2 Makita XPH01 Forward/Reverse Switch Replacement: 步骤 9 中的图像 2,2
    • Grab onto the forward/reverse switch.
    • Gently pull the forward/reverse switch to separate it from the trigger assembly.
结论
2等其他人完成本指南。
Eric Herwatt
于10/05/16注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 55
总计 5,811
