跳转到主内容
Makita XPH01 Clutch Leaf Spring Replacement
你所需要的
  1. Makita XPH01 Clutch Leaf Spring Replacement, Battery: 步骤 1 中的图像 1,1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 2 中的图像 1,1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 3 中的图像 1,1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 步骤 4 中的图像 1,2 Makita XPH01 Clutch Leaf Spring Replacement, Outer Casing: 步骤 4 中的图像 2,2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 5 中的图像 1,1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 6 中的图像 1,2 Makita XPH01 Clutch Leaf Spring Replacement: 步骤 6 中的图像 2,2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 7 中的图像 1,2 Makita XPH01 Clutch Leaf Spring Replacement: 步骤 7 中的图像 2,2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 Clutch Leaf Spring Replacement, Clutch Leaf Spring: 步骤 8 中的图像 1,1
    • Pull the silver metal clip located towards the back of the motor assembly away from the drill.
  9. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 9 中的图像 1,2 Makita XPH01 Clutch Leaf Spring Replacement: 步骤 9 中的图像 2,2
    • Grip the motor comfortably towards the front of the assembly, and pull it away from the outer casing.
    • The wires are still connected to the back of the motor assembly, so use caution when pulling the motor out. Failing to do this will result in parts falling off the back of the motor.
  10. Makita XPH01 Clutch Leaf Spring Replacement: 步骤 10 中的图像 1,2 Makita XPH01 Clutch Leaf Spring Replacement: 步骤 10 中的图像 2,2
    • Slide the clutch leaf spring off with the spudger.
结论
另外一个人完成了本指南。
Eric Herwatt
于10/05/16注册
984 声望
创作了7篇指南
团队
Cal Poly, Team 15-4, Livingston Fall 2016 Cal Poly, Team 15-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 2,980
