跳转到主内容
Makita Jack Hammer HM1307CB Handle Replacement
你所需要的
  1. Makita Jack Hammer HM1307CB Handle Replacement, Remove six screws from the handle: 步骤 1 中的图像 1,1
    • Remove the following screws:
    • Two Phillips screws
    • Four hex screws
    • These four hex screws are all held in place with threadlocker, and may take quite a bit of torque or even some heat to loosen.
    • During reassembly, clean the residual threadlocker from these screws, then reapply high-strength (red) threadlocker to each one before reinstalling.
    • If you aren't sure how to apply threadlocker, refer to the next step in this guide.
  2. Makita Jack Hammer HM1307CB Handle Replacement: 步骤 2 中的图像 1,3 Makita Jack Hammer HM1307CB Handle Replacement: 步骤 2 中的图像 2,3 Makita Jack Hammer HM1307CB Handle Replacement: 步骤 2 中的图像 3,3
    • To reapply threadlocker:
    • First, clean the residual threadlocker from each of the screws with some cleaner/degreaser and a stiff brush.
    • Second, apply a couple drops of high-strength threadlocker to the screw sockets.
    • Finally, apply one or two drops of the same high-strength threadlocker to the tip of each screw and reinstall them.
  3. Makita Jack Hammer HM1307CB Handle Replacement, Remove the handle: 步骤 3 中的图像 1,2 Makita Jack Hammer HM1307CB Handle Replacement, Remove the handle: 步骤 3 中的图像 2,2
    • Grab the handle and remove it from the jack hammer.
结论
To reassemble your device, follow these instructions in reverse order, taking note of any reassembly tips.
Taylor Dixon
于06/26/18注册
67,017 声望
创作了94篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 591
