简介
This guide will show you how to replace the grease in your angle grinder should it become dirty and fail to lubricate the gears.
配件
没有特定配件。
Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
2等其他人完成本指南。
4条评论
Hi, what is the recommended grease?
Hi. You’re great.
Can I use white lithium grease. Thanks my brushes appear to about half an inch long if the grease doesn’t work going to try them????
Angle grinders use a PAO lithium soap grease. Most use Nye Lubricants RheoLube 380, which is hard to source or expensive to buy.
You may substitute with Dupont Molykote G4700 grease. ereplacementParts.com has the Nye grease.
