跳转到主内容
Makita GA4030K Electrical Cord Replacement
你所需要的
  1. Makita GA4030K Electrical Cord Replacement, Back Cover: 步骤 1 中的图像 1,2 Makita GA4030K Electrical Cord Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  2. Makita GA4030K Electrical Cord Replacement: 步骤 2 中的图像 1,1
    • Slide the back cover down the power cable.
  3. Makita GA4030K Electrical Cord Replacement, Electrical Cord: 步骤 3 中的图像 1,3 Makita GA4030K Electrical Cord Replacement, Electrical Cord: 步骤 3 中的图像 2,3 Makita GA4030K Electrical Cord Replacement, Electrical Cord: 步骤 3 中的图像 3,3
    • Place your finger in the gap in front of the switch.
    • At the base of the device, push the switch lever into the 'on' position.
  4. Makita GA4030K Electrical Cord Replacement: 步骤 4 中的图像 1,1
    • Keeping the switch lever in the 'on' position, remove the switch.
    • When reinserting the switch, place the switch in the hole without pressing the switch lever in. Holding the switch against the back edge of the hole, push the switch lever fully into the 'on' position and then let go. The switch should catch onto the switch lever and remain attached.
  5. Makita GA4030K Electrical Cord Replacement: 步骤 5 中的图像 1,3 Makita GA4030K Electrical Cord Replacement: 步骤 5 中的图像 2,3 Makita GA4030K Electrical Cord Replacement: 步骤 5 中的图像 3,3
    • Pull the switch lever up and out of the body of the angle grinder.
  6. Makita GA4030K Electrical Cord Replacement: 步骤 6 中的图像 1,3 Makita GA4030K Electrical Cord Replacement: 步骤 6 中的图像 2,3 Makita GA4030K Electrical Cord Replacement: 步骤 6 中的图像 3,3
    • Pull back the plastic clip and pull the internal switch up and out of the cavity.
  7. Makita GA4030K Electrical Cord Replacement: 步骤 7 中的图像 1,3 Makita GA4030K Electrical Cord Replacement: 步骤 7 中的图像 2,3 Makita GA4030K Electrical Cord Replacement: 步骤 7 中的图像 3,3
    • Remove the two 10 mm screws holding the power cord leads in place using a Phillips #02 screwdriver.
    • When reassembling, be sure to attach the electrical cabling in the same positions.
  8. Makita GA4030K Electrical Cord Replacement: 步骤 8 中的图像 1,3 Makita GA4030K Electrical Cord Replacement: 步骤 8 中的图像 2,3 Makita GA4030K Electrical Cord Replacement: 步骤 8 中的图像 3,3
    • Unscrew the 2 mm tapping screw using a Phillips #02 screwdriver.
    • Lift the clasp up and out to remove it.
  9. Makita GA4030K Electrical Cord Replacement: 步骤 9 中的图像 1,1
    • Remove the electrical cable.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G5
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 29
总计 2,968
