跳转到主内容
Making Visible the Users Library Directory in OS X Lion
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: 步骤 1 中的图像 1,2 Making Visible the Users Library Directory in OS X Lion, Making Visible the Users Library Directory in OS X Lion: 步骤 1 中的图像 2,2
    • Many Macintosh users were excited when OS X 10.7 (Lion) was released, but after using it for a short time, many users realized that something was missing from lion.
    • The users Library directory is not where it it should be, infact, it is nowhere to be found. Fortunately, it is very simple to bring back the disappearing Library.
  2. Making Visible the Users Library Directory in OS X Lion: 步骤 2 中的图像 1,1
    • To begin the process, you will need to go to your Applications folder, which can be found in your Finder side bar.
    • Once in the Applications folder, you will want to find the Utilities folder.
  3. Making Visible the Users Library Directory in OS X Lion: 步骤 3 中的图像 1,1
    • After navigating to the Utilities folder you will need to scroll down to find the Terminal application.
  4. Making Visible the Users Library Directory in OS X Lion: 步骤 4 中的图像 1,2 Making Visible the Users Library Directory in OS X Lion: 步骤 4 中的图像 2,2
    • Once you have opened Terminal, you will need to type chflags nohidden ~/Library/ and then press Enter.
    • This will immediately make your Library folder visible under your user.
  5. Making Visible the Users Library Directory in OS X Lion: 步骤 5 中的图像 1,1
    • Once you have finished with Terminal, type exit to end your terminal processes. After you have typed this and hit enter you may quit out of Terminal.
  6. Making Visible the Users Library Directory in OS X Lion: 步骤 6 中的图像 1,1
    • To hide the Library folder, simply type chflags hidden ~/Library and press Enter.
    • Remember to type exit and press Enter before quitting Terminal.
结论
另外一个人完成了本指南。
Owen Cunneely
于12/01/10注册
7,139 声望
撰写一个指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,673篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,432
