跳转到主内容
加入维修社区 - 创建账户
Makerbot Digitizer stepper bracket Replacement
你所需要的
  1. Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: 步骤 1 中的图像 1,2 Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: 步骤 1 中的图像 2,2
    • Use a flat spudger or screwdriver to remove the 1-1/2" cap from the turntable center.
    • There is a small indentation on the underside of one side of the cap.
  2. Makerbot Digitizer stepper bracket Replacement, Loosen the turntable screw: 步骤 2 中的图像 1,1
    • Loosen the exposed T15 screw.
    • You do not need to remove it from the turntable, but it must be completely loosened.
    • It has a series of metal-rubber-metal washers, and if you leave the screw in the turntable, you don't need to mess with the washers.
  3. Makerbot Digitizer stepper bracket Replacement, Remove turntable: 步骤 3 中的图像 1,3 Makerbot Digitizer stepper bracket Replacement, Remove turntable: 步骤 3 中的图像 2,3 Makerbot Digitizer stepper bracket Replacement, Remove turntable: 步骤 3 中的图像 3,3
    • Use two flat tools under both sides of the turntable to to pop it out.
    • The turntable slides down onto the bearing with some friction, but I've taken mine on and off 10 times and it still fits snugly.
  4. Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 步骤 4 中的图像 1,3 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 步骤 4 中的图像 2,3 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 步骤 4 中的图像 3,3
    • Remove two T15 screws that hold the stepper bracket in place.
  5. Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 步骤 5 中的图像 1,3 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 步骤 5 中的图像 2,3 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 步骤 5 中的图像 3,3
    • That's basically it. My stepper has enough slack to maneuver it around without further disassembly.
  6. Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 步骤 6 中的图像 1,3 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 步骤 6 中的图像 2,3 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 步骤 6 中的图像 3,3
    • To reinstall the turntable, the stepper side must go in first, in order for the turntable gears to align with the stepper gears.
    • Otherwise, the turntable will sit too high and not contact the stepper gear.
结论
To reassemble, just follow these instructions in reverse.
Job McKee
于10/07/12注册
241 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 7
过去 30 天: 20
总计 121
