跳转到主内容
Maisto Rock Crawler Truck Circuit Board Replacement
你所需要的
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 步骤 1 中的图像 1,2 Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: 步骤 1 中的图像 2,2
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: 步骤 2 中的图像 1,2 Maisto Rock Crawler Truck Circuit Board Replacement: 步骤 2 中的图像 2,2
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
结论
3等其他人完成本指南。
kevin
于02/10/16注册
874 声望
创作了6篇指南
团队
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G2
3 名成员
创作了6篇指南
9条评论
Can you do anything to it to make it stronger are powerful
Matt John - 回复
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - 回复
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - 回复
Can any one help as my rc rock crawler is not turning left or right
pankaj kapatia - 回复
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 5,429
