跳转到主内容
Maisto Rock Crawler Remote Circuit Board Replacement
你所需要的
  1. Maisto Rock Crawler Remote Circuit Board Replacement, Remote Circuit Board: 步骤 1 中的图像 1,1
    • Remove the batteries before doing anything.
    • Use the driver and bit J1 to remove the five 9.5mm Philips screws holding the remote together.
  2. Maisto Rock Crawler Remote Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Take off the half of the remote that had the screw heads facing up.
  3. Maisto Rock Crawler Remote Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Slide out the circuit board.
    • Use the soldering iron to desolder the 3 wires.
结论
5等其他人完成本指南。
kevin
于02/10/16注册
874 声望
创作了6篇指南
团队
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G2
3 名成员
创作了6篇指南
5条评论
Can you show the wheel controller mechanism. I can see 3 contacts on mine but I think mine is missing something that would bring the contacts together as you turn the wheel to steer left and right. Thanks.
Ferdinand Fong - 回复
the triger is broken to drive the truck
joey heller - 回复
Somebody have the remote control for
Theodore Brock - 回复
I have a 1970 R/T charger RC car, 2.4GHz, I changed it up fully, but the pairing light wont come on. But I can show the lights,the control power is good.what is wrong can anybody help me find the problem and fix it.
Keith Pryor - 回复
How to pair new controller ?
Karel Říha - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 4,580
