跳转到主内容
Maisto Rock Crawler Rear Axle Replacement
你所需要的
  1. Maisto Rock Crawler Rear Axle Replacement, Rear Axle: 步骤 1 中的图像 1,1
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7 mm Phillips screws highlighted.
  2. Maisto Rock Crawler Rear Axle Replacement: 步骤 2 中的图像 1,1
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Rear Axle Replacement: 步骤 3 中的图像 1,1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5 mm Phillips screws.
  4. Maisto Rock Crawler Rear Axle Replacement: 步骤 4 中的图像 1,1
    • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Phillips screws that hold the side circuit board in.
  5. Maisto Rock Crawler Rear Axle Replacement: 步骤 5 中的图像 1,1
    • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
  6. Maisto Rock Crawler Rear Axle Replacement: 步骤 6 中的图像 1,1
    • Flip the R/C truck over again.
    • Remember which wire is connected at which pin before desoldering.
    • Desolder the 2 wires connected from the rear axle to the circuit board.
  7. Maisto Rock Crawler Rear Axle Replacement: 步骤 7 中的图像 1,1
    • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
结论
另外一个人完成了本指南。
kevin
于02/10/16注册
874 声望
创作了6篇指南
团队
USF Tampa, Team 1-2, Sullivan Spring 2016 USF Tampa, Team 1-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G2
3 名成员
创作了6篇指南
2条评论
Nice guide. Do you know where to buy parts for the repairment? I have searched all over but cannot seem to find any parts.
martinrene - 回复
Your best bet is a hobby shop I haven't seen any online sources myself
kevin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 2,429
