跳转到主内容
加入维修社区 - 创建账户
Main Click Buttons
你所需要的
  1. Main Click Buttons, Click Buttons: 步骤 1 中的图像 1,2 Main Click Buttons, Click Buttons: 步骤 1 中的图像 2,2
    • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
  2. Main Click Buttons: 步骤 2 中的图像 1,2 Main Click Buttons: 步骤 2 中的图像 2,2
    • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
  3. Main Click Buttons: 步骤 3 中的图像 1,2 Main Click Buttons: 步骤 3 中的图像 2,2
    • Use a blue spudger to open the bottom battery port.
  4. Main Click Buttons: 步骤 4 中的图像 1,2 Main Click Buttons: 步骤 4 中的图像 2,2
    • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
  5. Main Click Buttons: 步骤 5 中的图像 1,3 Main Click Buttons: 步骤 5 中的图像 2,3 Main Click Buttons: 步骤 5 中的图像 3,3
    • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
结论
18等其他人完成本指南。
6指南评论
how are you supposed to put the feet back?
Owen Yuen - 回复 分享
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - 分享
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - 分享
Are the side buttons the same?
S I - 回复 分享
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 32
过去 30 天: 123
总计 24,869
