跳转到主内容
加入维修社区 - 创建账户
Main Board Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Main Board Removal, Remove the stand screw: 步骤 1 中的图像 1,1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. Main Board Removal, Remove the vertical stand: 步骤 2 中的图像 1,2 Main Board Removal, Remove the vertical stand: 步骤 2 中的图像 2,2
    • Lift straight up to remove the stand.
  3. Main Board Removal, Store the stand screw: 步骤 3 中的图像 1,2 Main Board Removal, Store the stand screw: 步骤 3 中的图像 2,2
    • Insert the screw into the cubby on the bottom of the stand.
  4. Main Board Removal, Cap the screw hole: 步骤 4 中的图像 1,3 Main Board Removal, Cap the screw hole: 步骤 4 中的图像 2,3 Main Board Removal, Cap the screw hole: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. Main Board Removal, Close the cubby: 步骤 5 中的图像 1,3 Main Board Removal, Close the cubby: 步骤 5 中的图像 2,3 Main Board Removal, Close the cubby: 步骤 5 中的图像 3,3
    • Twist the stand counterclockwise to close the cubby.
  6. Main Board Removal, Remove the horizontal stand: 步骤 6 中的图像 1,2 Main Board Removal, Remove the horizontal stand: 步骤 6 中的图像 2,2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. Main Board Removal, Remove the right faceplate: 步骤 7 中的图像 1,3 Main Board Removal, Remove the right faceplate: 步骤 7 中的图像 2,3 Main Board Removal, Remove the right faceplate: 步骤 7 中的图像 3,3
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. Main Board Removal: 步骤 8 中的图像 1,2 Main Board Removal: 步骤 8 中的图像 2,2
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. Main Board Removal, Pry up the grille: 步骤 9 中的图像 1,3 Main Board Removal, Pry up the grille: 步骤 9 中的图像 2,3 Main Board Removal, Pry up the grille: 步骤 9 中的图像 3,3
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. Main Board Removal, Remove the grille: 步骤 10 中的图像 1,2 Main Board Removal, Remove the grille: 步骤 10 中的图像 2,2
    • Lift the grille away from the case to remove it.
  11. Main Board Removal, Remove the fan shroud screws: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a T9 Torx Security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. Main Board Removal, Remove the fan shroud: 步骤 12 中的图像 1,2 Main Board Removal, Remove the fan shroud: 步骤 12 中的图像 2,2
    • Lift the fan shroud straight up to remove it.
  13. Main Board Removal, Remove the wire cover: 步骤 13 中的图像 1,3 Main Board Removal, Remove the wire cover: 步骤 13 中的图像 2,3 Main Board Removal, Remove the wire cover: 步骤 13 中的图像 3,3
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. Main Board Removal: 步骤 14 中的图像 1,3 Main Board Removal: 步骤 14 中的图像 2,3 Main Board Removal: 步骤 14 中的图像 3,3
    • Use your fingers to peel off the wire cover.
  15. Main Board Removal, Disconnect the fan: 步骤 15 中的图像 1,2 Main Board Removal, Disconnect the fan: 步骤 15 中的图像 2,2
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. Main Board Removal, Remove the fan: 步骤 16 中的图像 1,3 Main Board Removal, Remove the fan: 步骤 16 中的图像 2,3 Main Board Removal, Remove the fan: 步骤 16 中的图像 3,3
    • Lift the fan up and out of the case to remove it.
  17. Main Board Removal, Remove the SSD cover: 步骤 17 中的图像 1,1
    • Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
  18. Main Board Removal: 步骤 18 中的图像 1,3 Main Board Removal: 步骤 18 中的图像 2,3 Main Board Removal: 步骤 18 中的图像 3,3
    • Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
    • Remove the SSD cover.
  19. Main Board Removal, Remove the optical drive wire: 步骤 19 中的图像 1,2 Main Board Removal, Remove the optical drive wire: 步骤 19 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
  20. Main Board Removal: 步骤 20 中的图像 1,2 Main Board Removal: 步骤 20 中的图像 2,2
    • Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
  21. Main Board Removal, Remove the tamper-evident sticker: 步骤 21 中的图像 1,3 Main Board Removal, Remove the tamper-evident sticker: 步骤 21 中的图像 2,3 Main Board Removal, Remove the tamper-evident sticker: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
    • If your PlayStation 5 hasn't been opened before, this sticker will be completely black. The pattern will appear after you remove it.
    • Technically, these are tamper-evident stickers—but don't worry—Sony can't legally void your warranty, as long as you don't damage anything. Have fun!
  22. Main Board Removal, Remove the case screws: 步骤 22 中的图像 1,1
    • Use a T8 Torx driver to remove the eleven screws securing the case:
    • Six 18.6 mm-long screws
    • Two 43.2 mm-long screws
    • One 7.3 mm-long screw
  23. Main Board Removal, Remove the case: 步骤 23 中的图像 1,2 Main Board Removal, Remove the case: 步骤 23 中的图像 2,2
    • Lift the case straight up to remove it.
  24. Main Board Removal, Remove the optical drive ribbon cable: 步骤 24 中的图像 1,3 Main Board Removal, Remove the optical drive ribbon cable: 步骤 24 中的图像 2,3 Main Board Removal, Remove the optical drive ribbon cable: 步骤 24 中的图像 3,3
    • Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
    • Pull only on the pull tab, not the cable itself.
  25. Main Board Removal, Remove the optical drive: 步骤 25 中的图像 1,2 Main Board Removal, Remove the optical drive: 步骤 25 中的图像 2,2
    • Lift the optical drive away from the device to remove it.
  26. Main Board Removal, Remove the optical drive ribbon cable: 步骤 26 中的图像 1,3 Main Board Removal, Remove the optical drive ribbon cable: 步骤 26 中的图像 2,3 Main Board Removal, Remove the optical drive ribbon cable: 步骤 26 中的图像 3,3
    在这个步骤中使用的工具:
    • With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
  27. Main Board Removal, Remove the power and eject button ribbon cable: 步骤 27 中的图像 1,2 Main Board Removal, Remove the power and eject button ribbon cable: 步骤 27 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
  28. Main Board Removal, Remove the LED ribbon cable: 步骤 28 中的图像 1,2 Main Board Removal, Remove the LED ribbon cable: 步骤 28 中的图像 2,2
    • Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
  29. Main Board Removal, Remove the antenna wires: 步骤 29 中的图像 1,3 Main Board Removal, Remove the antenna wires: 步骤 29 中的图像 2,3 Main Board Removal, Remove the antenna wires: 步骤 29 中的图像 3,3
    • Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
    • Lift the wire's connector straight up to disconnect it from the motherboard.
    • Repeat for the black Wi-Fi antenna wire.
    • Some board revisions may not have these antenna wires. If your board is missing these connectors, skip this step.
  30. Main Board Removal: 步骤 30 中的图像 1,3 Main Board Removal: 步骤 30 中的图像 2,3 Main Board Removal: 步骤 30 中的图像 3,3
    • Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
    • Repeat for the white power supply antenna wire.
  31. Main Board Removal, Remove the white stickers: 步骤 31 中的图像 1,3 Main Board Removal, Remove the white stickers: 步骤 31 中的图像 2,3 Main Board Removal, Remove the white stickers: 步骤 31 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
    • Remove the antenna wires from underneath the sticker.
    • Press the white sticker back down onto the top shield plate so it can be reused.
  32. Main Board Removal: 步骤 32 中的图像 1,3 Main Board Removal: 步骤 32 中的图像 2,3 Main Board Removal: 步骤 32 中的图像 3,3
    • Repeat the previous step to peel back the four remaining stickers.
  33. Main Board Removal: 步骤 33 中的图像 1,3 Main Board Removal: 步骤 33 中的图像 2,3 Main Board Removal: 步骤 33 中的图像 3,3
    • Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
    • Remove the LED ribbon cable from underneath the sticker.
    • Press the white sticker back down onto the heat sink so it can be reused.
  34. Main Board Removal, Remove the top shield plate screws: 步骤 34 中的图像 1,1
    • Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
    • Forty-one 7.3 mm-long screws
    • One 43.2 mm-long screw
  35. Main Board Removal, Remove the top shield plate: 步骤 35 中的图像 1,3 Main Board Removal, Remove the top shield plate: 步骤 35 中的图像 2,3 Main Board Removal, Remove the top shield plate: 步骤 35 中的图像 3,3
    • Lift the top shield plate off of the motherboard to remove it.
    • During reassembly, this is a good point to replace any thermal pads on the top of the main board, if necessary. The pads may be stuck to both the top shield plate and the main board.
    • It's important that the replacement pads are the same thickness as the originals, otherwise the foam around the APU may not seal properly.
  36. Main Board Removal, Disconnect the USB board: 步骤 36 中的图像 1,3 Main Board Removal, Disconnect the USB board: 步骤 36 中的图像 2,3 Main Board Removal, Disconnect the USB board: 步骤 36 中的图像 3,3
    • Use your finger to depress the metal locking tab on the USB board cable's board connector.
    • With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
  37. Main Board Removal, Remove the main board screws: 步骤 37 中的图像 1,2 Main Board Removal, Remove the main board screws: 步骤 37 中的图像 2,2
    • Use a Phillips screwdriver to remove the 11 mm‑long SSD screw.
    • Be careful not to lose the small spacer under the screw.
    • Use a Phillips screwdriver to remove the two 11.8 mm‑long APU tension bracket screws.
    • Don't remove or install one screw at a time, or you may damage the APU. During disassembly and reassembly, alternate between the two screws a 1/2 turn at a time to maintain even pressure on the bracket.
    • Use a TR8 Torx security screwdriver to remove the two remaining 7.3 mm‑long main board screws.
  38. Main Board Removal: 步骤 38 中的图像 1,3 Main Board Removal: 步骤 38 中的图像 2,3 Main Board Removal: 步骤 38 中的图像 3,3
    • Lift and remove both APU brackets from the board.
    • During reassembly:
    • Put the bracket with plastic arms on first so the pegs go into their cutouts.
    • Then, put the metal bracket onto the plastic one so they're perpendicular and the screw holes line up.
  39. Main Board Removal, Separate the main board: 步骤 39 中的图像 1,3 Main Board Removal, Separate the main board: 步骤 39 中的图像 2,3 Main Board Removal, Separate the main board: 步骤 39 中的图像 3,3
    • Don't try to fully remove the motherboard during this step—the corner near the power button is still secured by metal prongs, which will be disconnected in the next step.
    • Gently lift the edge of the motherboard with the large cutout to partially separate it from the bottom shield plate.
    • With the board lifted, insert the flat end of a spudger between the board and the bottom shield plate and gently twist to separate them. Work your way around the perimeter of the board.
    • Many small thermal pads bond the main board to the metal shield plate underneath. Depending on the age of your PlayStation and the condition of the pads, it may take significant force to separate the board.
  40. Main Board Removal: 步骤 40 中的图像 1,3 Main Board Removal: 步骤 40 中的图像 2,3 Main Board Removal: 步骤 40 中的图像 3,3
    • The power supply is connected to the bottom of the main board assembly by metal prongs that plug into the bottom left corner.
    • Insert the flat end of a spudger between the board and the lower shield plate, by the two parallel solder joints near the corner with the power button.
    • Twist the spudger to lift the two prongs under the board out of their socket.
    • You should feel the prongs slide out.
    • During reassembly, press down on the corner of the board to fully seat the prongs in the power supply—you should feel them slide into place.
  41. Main Board Removal, Remove the main board: 步骤 41 中的图像 1,2 Main Board Removal, Remove the main board: 步骤 41 中的图像 2,2
    • Remove the main board, flip it over, and carefully lay it on a clean work surface, so the APU is facing up.
    • Don't press the board against your work surface, or you may damage fragile components.
    • Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
    • Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
    • Keep the board level and lower it into place.
结论
Spencer Day
于09/14/22注册
159,563 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,966篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 114
