跳转到主内容
Magnavox MWD200F Disk Drive Replacement
你所需要的
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: 步骤 3 中的图像 1,1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: 步骤 5 中的图像 1,2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: 步骤 5 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: 步骤 6 中的图像 1,2 Magnavox MWD200F Disk Drive Replacement: 步骤 6 中的图像 2,2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: 步骤 7 中的图像 1,2 Magnavox MWD200F Disk Drive Replacement: 步骤 7 中的图像 2,2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: 步骤 8 中的图像 1,1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: 步骤 9 中的图像 1,2 Magnavox MWD200F Disk Drive Replacement: 步骤 9 中的图像 2,2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: 步骤 10 中的图像 1,3 Magnavox MWD200F Disk Drive Replacement: 步骤 10 中的图像 2,3 Magnavox MWD200F Disk Drive Replacement: 步骤 10 中的图像 3,3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: 步骤 11 中的图像 1,2 Magnavox MWD200F Disk Drive Replacement: 步骤 11 中的图像 2,2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
结论
Taryn
于09/15/11注册
109 声望
创作了4篇指南
团队
University of Maine, Team 1-2, Diaz Fall 2011 University of Maine, Team 1-2, Diaz Fall 2011 的会员
UMAINE-DIAZ-F11S1G2
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,490
