跳转到主内容
Magna Outreach Rear tire Replacement
你所需要的
  1. Magna Outreach Rear tire Replacement, Rear Tire: 步骤 1 中的图像 1,1
    • Disconnect the rear brake cable
  2. Magna Outreach Rear tire Replacement: 步骤 2 中的图像 1,1
    • Flip the bike over so that it is resting on the seat and handlebars.
    • Use an adjustable wrench to remove the nuts on both sides of the wheel that hold the wheel to the frame.
    • Lift the tire away from the frame and chain.
  3. Magna Outreach Rear tire Replacement: 步骤 3 中的图像 1,1
    • Insert one tire lever under the tire and hook it onto a spoke. Insert the other tire lever next to the first and slide it along the rim to remove one side of the tire from the rim.
  4. Magna Outreach Rear tire Replacement: 步骤 4 中的图像 1,1
    • Starting at the valve, pull the inner tube out of the gap between the rim and the tire.
  5. Magna Outreach Rear tire Replacement: 步骤 5 中的图像 1,1
    • Pull the tire away from the rim.
结论
另外一个人完成了本指南。
West Johnson
于10/06/14注册
146 声望
撰写一个指南
团队
USF Tampa, Team 1-14, Donnelly Fall 2014 USF Tampa, Team 1-14, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G14
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 2,486
