跳转到主内容
Magic Trackpad Battery Replacement
你所需要的
  1. Magic Trackpad Battery Replacement, Batteries: 步骤 1 中的图像 1,2 Magic Trackpad Battery Replacement, Batteries: 步骤 1 中的图像 2,2
    • Use a spudger or coin to twist out the battery door.
  2. Magic Trackpad Battery Replacement: 步骤 2 中的图像 1,1
    • Slide out the two AA batteries.
结论
3等其他人完成本指南。
Ronnie
于10/22/12注册
3,492 声望
创作了5篇指南
4条评论
Hello there, is the Trackpad destroyed by misplacing (wrong polarity) the batteries?
Toto1411 - 回复
I recently found a Magic Trackpad on a junk pile, to find that the batteries are corroded and won’t come out.
I poured a small amount of isopropyl alcohol in the battery cylider, pried with a thin plastic pick and banged it against a table to get out the first battery, but the second one doesn’t want to move.
Any suggestions for how to get it out without destroying the device? The only thing I can think of would be to crazy-glue a thin rod to the top of the battery, maybe pour in some alcohol, and pull/wiggle the battery until it comes out. I’m afraid that any kind of stronger solvent will cause real damage.
Opinions?
shamino - 回复
The best solvent for leaked alkaline batteries is… tap water!
michel.firholz -
I had corroded batteries in my Magic Keyboard. Exact same construction. I fashioned a thin blade from an aluminum can. It had enough column strength to slide between the battery and the aluminum battery compartment and with different solvents I was able to free the batteries. Now I have a trackpad that I am trying to recondition but not so easy. IPA and WD40 did not free the batteries this time, about to try dilute vinegar.
Eric Andersen - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 96
总计 12,536
