跳转到主内容
Magic Bullet NutriBullet Rubber Gasket Replacement
你所需要的
  1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: 步骤 1 中的图像 1,1
    • Separate the blending blade lid from the cup.
  2. Magic Bullet NutriBullet Rubber Gasket Replacement: 步骤 2 中的图像 1,2 Magic Bullet NutriBullet Rubber Gasket Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
    • Slowly pry the rubber gasket up.
结论
另外一个人完成了本指南。
Geary Yu
于01/22/15注册
1,268 声望
创作了3篇指南
团队
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G8
4 名成员
创作了13篇指南
11指南评论
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - 回复
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - 回复
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - 回复
Thanks a lot.
Kayla Martin -
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 36
过去 30 天: 146
总计 36,954
