本指南有最近更改,您可查看未经巡查的最新版本。
简介
On the top of the NutriBullet powerbase, there are three white activators that initiate the active blending process. This replacement guide will provide instructions on how to replace these activators.
你所需要的
Place the NutriBullet powerbase on the table so that the white activators are visible. Remove the three rubber protectors from the activators using either tweezers or your fingers.
Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
56等其他人完成本指南。
44条评论
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
Joe Bailey - 回复
