跳转到主内容
加入维修社区 - 创建账户
Magic Bullet NutriBullet Activator Replacement
你所需要的
    1. Magic Bullet NutriBullet Activator Replacement, Curve Base: 步骤 1 中的图像 1,1
      • Unplug the device from the wall and turn the powerbase upside down.
      询问修复机器人
      添加评论
    2. Magic Bullet NutriBullet Activator Replacement: 步骤 2 中的图像 1,2 Magic Bullet NutriBullet Activator Replacement: 步骤 2 中的图像 2,2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      询问修复机器人
      添加评论
    3. Magic Bullet NutriBullet Activator Replacement: 步骤 3 中的图像 1,1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      询问修复机器人
      添加评论
    4. Magic Bullet NutriBullet Activator Replacement: 步骤 4 中的图像 1,1
      • Lift the power cord to remove it from the side slot on the curved base.
      添加评论
    5. Magic Bullet NutriBullet Activator Replacement: 步骤 5 中的图像 1,2 Magic Bullet NutriBullet Activator Replacement: 步骤 5 中的图像 2,2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      添加评论
    6. Magic Bullet NutriBullet Activator Replacement: 步骤 6 中的图像 1,1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      询问修复机器人
      添加评论
    7. Magic Bullet NutriBullet Activator Replacement: 步骤 7 中的图像 1,1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      询问修复机器人
      添加评论
    1. Magic Bullet NutriBullet Activator Replacement, Outside Casing: 步骤 8 中的图像 1,1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      添加评论
    1. Magic Bullet NutriBullet Activator Replacement, Rubber Covers: 步骤 9 中的图像 1,1
      在这个步骤中使用的工具:
      • Place the NutriBullet powerbase on the table so that the three rubber screw covers are visible along the bottom of the well. Remove the covers using either tweezers or your fingers.
      添加评论
    2. Magic Bullet NutriBullet Activator Replacement, Top Screws: 步骤 10 中的图像 1,1
      • Remove the three 15mm screws with the Philips Head 2 Screwdriver.
      添加评论
    3. Magic Bullet NutriBullet Activator Replacement: 步骤 11 中的图像 1,1
      • Turn the NutriBullet powerbase upside down and remove the plastic casing by lifting it up. You may have to wiggle the casing in order to break away any hardened material.
      添加评论
    4. Magic Bullet NutriBullet Activator Replacement: 步骤 12 中的图像 1,1
      • Determine which activator(s) fail to work by applying pressure to them. Then, remove the two 15mm screws that hold the activators in place by using the Philips Head 2 screwdriver.
      • Only two of the three activator tabs have green micro switches that actually turn on the motor. Use a circuit tester on the power chord and press the two micro switches simultaneously to see if they complete the circuit. If not, one or both need to be replaced.
      添加评论
    5. Magic Bullet NutriBullet Activator Replacement: 步骤 13 中的图像 1,3 Magic Bullet NutriBullet Activator Replacement: 步骤 13 中的图像 2,3 Magic Bullet NutriBullet Activator Replacement: 步骤 13 中的图像 3,3
      • Using slight tension, pull the loose activator from the slot.
      • The white plastic activator should fall out and they can now be replaced.
      添加评论
    6. Magic Bullet NutriBullet Activator Replacement, Repairing internal switches: 步骤 14 中的图像 1,1
      • Open up the green switch. The metal tab and black button will fall out. Fiddle around with the metal switch on the inside to snap it back into place and then reassemble carefully. It should make a clicking noise.
      添加评论
      • Before reassembling, you should clean up any material that has accumulated on the various parts. Be sure to keep water away from the motor, switches and other electrical components.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
62等其他人完成本指南。
Angela Wong
于01/22/15注册
1,177 声望
创作了3篇指南
团队
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G8
4 名成员
创作了28篇指南
47指南评论
Seems to be almost complete info, however, where and how do I get the replacement parts?
Thank you!
Love&Peace!
Glow
Glow Wo - 回复 分享
Could you please let me know where I might be able to obtain replacement activators? Mind broke when cleaning the machine.
Ron - 回复 分享
Thank you. I would have went nuts looking for the screw under the rubber pieces. Would have probably destroyed the whole machine.
Joe Bailey - 回复 分享
Thanks for the demonstration!
D S Jones - 回复 分享
Perfect! Nice little machine that can still be serviced, unlike most of what is made today.
cward6681 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 110
过去 30 天: 513
总计 99,115
