跳转到主内容
Magic Bullet MB1001B Power Cord Replacement
你所需要的
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: 步骤 3 中的图像 1,1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: 步骤 5 中的图像 1,1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: 步骤 6 中的图像 1,1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: 步骤 7 中的图像 1,1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
结论
2等其他人完成本指南。
Bridget Carr
于10/06/15注册
266 声望
撰写一个指南
团队
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G13
4 名成员
创作了8篇指南
2指南评论
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - 回复
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,715
