跳转到主内容
Magellan Roadmate 9055-LM Button Replacement
你所需要的
  1. Magellan Roadmate 9055-LM Button Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: 步骤 1 中的图像 1,1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Button Replacement: 步骤 2 中的图像 1,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 2 中的图像 2,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 2 中的图像 3,3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Button Replacement: 步骤 3 中的图像 1,2 Magellan Roadmate 9055-LM Button Replacement: 步骤 3 中的图像 2,2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Button Replacement: 步骤 4 中的图像 1,2 Magellan Roadmate 9055-LM Button Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Button Replacement: 步骤 5 中的图像 1,1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Button Replacement: 步骤 6 中的图像 1,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 6 中的图像 2,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 6 中的图像 3,3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Button Replacement: 步骤 7 中的图像 1,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 7 中的图像 2,3 Magellan Roadmate 9055-LM Button Replacement: 步骤 7 中的图像 3,3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Button Replacement: 步骤 8 中的图像 1,1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Button Replacement, Button: 步骤 9 中的图像 1,1
    • Locate button
  10. Magellan Roadmate 9055-LM Button Replacement: 步骤 10 中的图像 1,1
    • The button can be easily removed and can now be replaced
结论
Giovanni
于10/18/16注册
313 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-5, Catania Fall 2016 UMass Dartmouth, Team 1-5, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 78
