跳转到主内容
Magellan RoadMate 5250T-LM Screen Replacement
你所需要的
  1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: 步骤 1 中的图像 1,2 Magellan RoadMate 5250T-LM Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
    • Place screws aside. Make sure they are easily accessible for reassembling the device.
  2. Magellan RoadMate 5250T-LM Screen Replacement: 步骤 2 中的图像 1,2 Magellan RoadMate 5250T-LM Screen Replacement: 步骤 2 中的图像 2,2
    • Lift the back cover using a spudger.
    • Remove back cover slowly and carefully to prevent damage.
  3. Magellan RoadMate 5250T-LM Screen Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Peel back the tape securing the display connector to the motherboard.
    • To ensure proper reassembly, do not remove or fold edges of tape.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Screen Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 5250T-LM Screen Replacement: 步骤 4 中的图像 2,2
    • Undo the four clamps holding down the display.
    • Remove the display from the front cover.
结论
Jaimee Mound
于01/31/16注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 347
