跳转到主内容
Magellan RoadMate 5236T-LM Display Screen Replacement
你所需要的
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 步骤 1 中的图像 1,3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 步骤 1 中的图像 2,3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: 步骤 2 中的图像 1,3 Magellan RoadMate 5236T-LM Display Screen Replacement: 步骤 2 中的图像 2,3 Magellan RoadMate 5236T-LM Display Screen Replacement: 步骤 2 中的图像 3,3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 5236T-LM Display Screen Replacement: 步骤 3 中的图像 2,2
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 步骤 4 中的图像 1,3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 步骤 4 中的图像 2,3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: 步骤 4 中的图像 3,3
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
结论
2等其他人完成本指南。
Megan Scribner
于10/18/16注册
315 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Catania Fall 2016 UMass Dartmouth, Team 4-7, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G7
3 名成员
创作了5篇指南
一条评论
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 562
