跳转到主内容
Magellan RoadMate 5120-LMTX Speaker Replacement
你所需要的
  1. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: 步骤 1 中的图像 1,3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: 步骤 1 中的图像 2,3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Speaker Replacement: 步骤 2 中的图像 1,3 Magellan RoadMate 5120-LMTX Speaker Replacement: 步骤 2 中的图像 2,3 Magellan RoadMate 5120-LMTX Speaker Replacement: 步骤 2 中的图像 3,3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Open the device and remove the tape from the speaker wire using the spudger.
  4. Magellan RoadMate 5120-LMTX Speaker Replacement: 步骤 4 中的图像 1,2 Magellan RoadMate 5120-LMTX Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the two 4mm Phillips #00 screws securing the speaker assembly and remove speaker.
结论
Chris Blaskowski
于10/08/16注册
370 声望
创作了3篇指南
团队
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 的会员
IUPUI-WILSON-F16S4G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 134
