跳转到主内容
Magellan RoadMate 5120-LMTX Motherboard Replacement
你所需要的
  1. Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 2 中的图像 1,3 Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 2 中的图像 2,3 Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 2 中的图像 3,3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Magellan RoadMate 5120-LMTX Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 4 中的图像 1,3 Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 4 中的图像 2,3 Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 4 中的图像 3,3
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 5 中的图像 1,2 Magellan RoadMate 5120-LMTX Motherboard Replacement: 步骤 5 中的图像 2,2
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
结论
Andrew Bading
于10/08/16注册
132 声望
撰写一个指南
团队
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 的会员
IUPUI-WILSON-F16S4G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 306
