跳转到主内容
Magellan RoadMate 5120-LMTX Battery Replacement
你所需要的
  1. Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Magellan RoadMate 5120-LMTX Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 2 中的图像 1,3 Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 2 中的图像 2,3 Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 2 中的图像 3,3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Battery Replacement, Battery: 步骤 3 中的图像 1,2 Magellan RoadMate 5120-LMTX Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
    • Still using the spudger tool, pry the battery from the housing.
    • If you damage the tape while trying to remove the battery, you can replace it with any double-sided tape.
  4. Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 4 中的图像 1,3 Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 4 中的图像 2,3 Magellan RoadMate 5120-LMTX Battery Replacement: 步骤 4 中的图像 3,3
    • Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
    • There is a clear rectangular adhesive strip that also needs to be removed with the pointy end of a spudger.
    • Slowly pull the connection from the motherboard.
    • Do not pull too hard or you will risk damaging the wires.
结论
Steven Prout
于10/08/16注册
231 声望
创作了2篇指南
团队
IUPUI, Team 4-4, Wilson Fall 2016 IUPUI, Team 4-4, Wilson Fall 2016 的会员
IUPUI-WILSON-F16S4G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 477
