跳转到主内容
Magellan RoadMate 2120T-LM Battery Replacement
你所需要的
  1. Magellan RoadMate 2120T-LM Battery Replacement, Battery: 步骤 1 中的图像 1,3 Magellan RoadMate 2120T-LM Battery Replacement, Battery: 步骤 1 中的图像 2,3 Magellan RoadMate 2120T-LM Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Battery Replacement: 步骤 2 中的图像 1,2 Magellan RoadMate 2120T-LM Battery Replacement: 步骤 2 中的图像 2,2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Battery Replacement: 步骤 3 中的图像 1,1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Battery Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 328
