跳转到主内容
Magellan RoadMate 1440 Speaker Replacement
你所需要的
  1. Magellan RoadMate 1440 Speaker Replacement, Magellan RoadMate 1440 Back Cover Disassembly: 步骤 1 中的图像 1,1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Speaker Replacement: 步骤 2 中的图像 1,2 Magellan RoadMate 1440 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Speaker Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 1440 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Speaker Replacement: 步骤 4 中的图像 1,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 4 中的图像 2,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 4 中的图像 3,3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Speaker Replacement: 步骤 5 中的图像 1,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 5 中的图像 2,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 5 中的图像 3,3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Speaker Replacement, Battery: 步骤 6 中的图像 1,2 Magellan RoadMate 1440 Speaker Replacement, Battery: 步骤 6 中的图像 2,2
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Speaker Replacement: 步骤 7 中的图像 1,2 Magellan RoadMate 1440 Speaker Replacement: 步骤 7 中的图像 2,2
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Speaker Replacement: 步骤 8 中的图像 1,2 Magellan RoadMate 1440 Speaker Replacement: 步骤 8 中的图像 2,2
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Speaker Replacement, Speaker: 步骤 9 中的图像 1,3 Magellan RoadMate 1440 Speaker Replacement, Speaker: 步骤 9 中的图像 2,3 Magellan RoadMate 1440 Speaker Replacement, Speaker: 步骤 9 中的图像 3,3
    • After the back has been removed, locate each of the screws securing the speaker to the inside of the back cover.
    • Use a Phillips #0 screwdriver to remove the two 3.8mm Phillips #0 screws.
  10. Magellan RoadMate 1440 Speaker Replacement: 步骤 10 中的图像 1,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 10 中的图像 2,3 Magellan RoadMate 1440 Speaker Replacement: 步骤 10 中的图像 3,3
    • The speaker is connected to the motherboard by a few wires
    • Gently remove the connector from the motherboard to completely remove the speaker.
结论
Lauren Cain
于03/21/16注册
103 声望
撰写一个指南
团队
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 208
