跳转到主内容
Magellan RoadMate 1440 Power Switch Replacement
你所需要的
  1. Magellan RoadMate 1440 Power Switch Replacement, Magellan RoadMate 1440 Back Cover Disassembly: 步骤 1 中的图像 1,1
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Power Switch Replacement: 步骤 2 中的图像 1,2 Magellan RoadMate 1440 Power Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Power Switch Replacement: 步骤 3 中的图像 1,2 Magellan RoadMate 1440 Power Switch Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Power Switch Replacement: 步骤 4 中的图像 1,3 Magellan RoadMate 1440 Power Switch Replacement: 步骤 4 中的图像 2,3 Magellan RoadMate 1440 Power Switch Replacement: 步骤 4 中的图像 3,3
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Power Switch Replacement: 步骤 5 中的图像 1,3 Magellan RoadMate 1440 Power Switch Replacement: 步骤 5 中的图像 2,3 Magellan RoadMate 1440 Power Switch Replacement: 步骤 5 中的图像 3,3
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Power Switch Replacement, Power Switch: 步骤 6 中的图像 1,1
    • Once the back cover has been removed, lift the power switch from the device.
    • This is only a sliding switch, the button to power the device on is inside the unit
结论
Jeremy Johnson
于03/21/16注册
201 声望
创作了2篇指南
团队
Clemson, Team 7-3, Benson Spring 2016 Clemson, Team 7-3, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G3
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 193
